New to fusing
New to fusing
I am new to fusing. What is the best size of glass to use for fusing/slumping?
Re: New to fusing
It doesn't matter. If you fuse it long enough, it will be 1/4" thick.Deb wrote:I am new to fusing. What is the best size of glass to use for fusing/slumping?
If you're new to fusing, spend some time with the tutorial: http://www.warmglass.com/Basic.htm
Re: New to fusing
exactly the size that is required to make whatever you're making.Deb wrote:I am new to fusing. What is the best size of glass to use for fusing/slumping?
