Potmelt from transparent glass
Jan de Jong
Hello ! Is it possible to do a potmelt with only transparant glass colours ? I did try it once.....all colours became dark ? Thank you ! Jan
Re: Potmelt from transparent glass
You will need to have your pot filled with at least 50% clear plus stick with lighter shades of transparent glass!
Avoid reds, and pay attention to not mix reactive colors (or at least separate them from each other with a layer of clear).
Jan de Jong
Thank you both for your answer ! I will try again. Jan de Jong
In addition to reds...orange and yellow transparents will have a tendency to opalize at pot melt temperatures. So, unless you’d like this effect, you should avoid these colors.
Jan de Jong
Thank you Sharol ! Jan
