Round piece of glass.....sagging
Hello ! I have no idea what will happen when you let sagg a round piece of glass. Is there anywhere a photo of this ?? Thank you, Jan de Jong
Re: Round piece of glass.....sagging
@ Jim Simmons: 26 cm diameter over kilnstands with on the top ceramic thick paper (felt ?). As I did for tealights but then square and not so big. Jan
The circle will sag like the square, by folding in a few places. If centered on the post it will end up with even height edges without the peaks you get with a square drape/sag.
Do a test with a circle of float to see if you get the effect you want.
Jim
Jim
@ The Hobbyist: Thank you ! I will do a test. Jan de Jong
