stainless steel molds
Celeste Stuhring
Post by Celeste Stuhring »
As long as they are coated properly, can you use any stainless steel bowl for draping? Any thickness? I found an unusual shape that I would love to use for draping..It says this...The bowls are Food grade 304 stainless steel and FDA approved. German technology designed for higher temperature, pressure and corrosion resistance. High quality, recyclable, last long and eco-friendly, also they are heavy duty brushed stainless on the outside which is the side I want to use. Thanks for any answers.
Dick
Re: stainless steel molds
Post by Dick »
Yep. I sandblast and coat with kilnwash while hot for best results
Post by Marty »
Spray the kw on.
