crinklized cbs glass
Linda Hassur
I have been unable to get an answer from the CBS company regarding firing this glass in the kiln. I wanted to know if it needs to be capped with a clear glass or can it be fired without. Are there any problems with firing this glass as there is with dichroic (one side up or down) . It's too expensive to experiment so would appreciate any information others may have using this glass. Years ago I was on this forum quite a bit but haven't posted for years. I find like I have found my "old" friends and am anxious to start using all of the information available through it. thanks Linda
Re: crinklized cbs glass
It can be fired without being capped but the top surface will be quite rough.
I have had several occasions where small flecks of dichro coating popped around when fired.
http://www.Kaiserglass.com
glass classes;
Tutorials; [/b]
Facebook:[/b]
glass classes;
Tutorials; [/b]
Facebook:[/b]
Firing dichro down usually works better, plus never any sticking. I have had a little dichro pop off when face up. Problem is if you want to cap, you need to fire first as the dichro tends to bubble when capped
