Hi All,
I know someone who has a few annealing kilns for use by glass blowers. He wonders if they could also be used for fusing. I am not familiar with annealers.
Can they be also used for fusing?
Thanks!
Anneling kiln for fusing?
Bonnie Rubinstein
Re: Anneling kiln for fusing?
It should as long as it will fire to the processing temps you need for your work. The Skutt ones I looked at had a top temp of 1700*, which is higher than you need for Bullseye glass.
Mark Hughes
Thank you. he said it does go to 1400.
I should probably check to see what his controller looks like.
Bonnie Rubinstein
