Hi All,
I am looking at the adjustabail system to hang larger glass panels (about 15 lbs.) I usually use large metal standoffs. (Visually not desirable and complicated for clients). How does the adjustsbail compare to Hang Your Glass systems, and would this be reliable on the back side of fused glass, which is not smooth?
thx!
adjustabail (?)
Bonnie Rubinstein
adjustabail (?)
Bonnie Rubinstein
Bonnie Rubinstein
Re: adjustabail (?)
anyone try these?
aae glass sells them.
I'd love to get feedback.
Bonnie Rubinstein
Re: adjustabail (?)
Haven't used them, but you might check out the website (this is a UK company): https://adjustabail.co.uk/
There are also a few Facebook comments.
Bonnie Rubinstein
Re: adjustabail (?)
Yep, I had done the research , but did not find anyone using them for larger panels. Would appreciate knowing if they work for them!
Bonnie Rubinstein
The Hobbyist
Re: adjustabail (?)
I have a several pieces mounted using the Hang Your Glass. They've been there for a few years. They weigh about 5 lbs each. Three of them are mounted outdoors (house numbers).
They all use the smaller size mounts (three or four for each one). The larger size hold more weight. The company website and adverts should give the weight ranges.
The back surface where mine are glued has the texture from the kilnwashed shelf.
It appears the glue (a version of epoxy?) is very strong and stable...so far.
Jim
Jim
Bonnie Rubinstein
Re: adjustabail (?)
Hi Jim,
I am looking at Hang Your Glass grips now. I have several that I have never used, and will use one as a tester. The adhesive is from about 2018, never opened, but I understand the adhesive expires, so will need to get more of that. I think their adhesive is the only one they recommend. Any thoughts?
Thanks!
Thanks!
Bonnie Rubinstein
