Based on a bad incident, I will succumb and wear gloves in the studio. What is recommended to pick up small pieces of glass, and still provide protection?
Thanks!
strong, but thin gloves?
Bonnie Rubinstein
Bonnie Rubinstein
Re: strong, but thin gloves?
Here are some options:
Nitrile gloves, durable and resistant to puncture. Not quite as flexible as
Latex surgical gloves, which are more prone to puncture than nitrile gloves.
Vinyl gloves are thin, but prone to puncture
Neoprene gloves are designed to replicate latex (some people are allergic to latex).
I'd try several and see which works best for you. We mostly use nitrile, which does come in different thicknesses.
Brad
Brad
Bonnie Rubinstein
I have tried about 2 dozen different gloves.
The nitrile are hard to get on and off, especially if the hand sweats inside (which they do). the box i have has 9mil gloves. What mil do you use, Brad?
Thanks for the info. So, I may just keep using these, because i can pick up small pieces, a huge benefit.
Bonnie Rubinstein
We mostly use 5 mil, which might be easier than 9 mil to get on and off, but they're still hard to remove, especially if you're sweating.
Vinyl gloves would be easier to remove, but they're not very durable.
I like Costco nitrile gloves, I often end up dusting my hand with kiln wash and it makes gloves easier to put on.
