I'm doing an experiment with float (not too familiar with it). I laid a bunch of small pieces and frit piled up on a 1/4" base, with some fine colored frit and dammed it. I originally programmed for 1550 with a 10 minute hold, but it wasn't flattened out, so I added time and temp and ended up at 1580 over about 15 more minutes. It flattened out somewhat, but it didn't flow on the surface like BE or Spectrum. There was of course some devit which was expected but I really want it to flow out to a smooth surface.
Will it flow if I take it higher and faster, or do I have to add some devit spray or flux or something to make the surface flat?
float and devit
Lynne Chappell
Brian and Jenny Blanthorn
Re: float and devit
Yo LynneLynne Chappell wrote:I'm doing an experiment with float (not too familiar with it). I laid a bunch of small pieces and frit piled up on a 1/4" base, with some fine colored frit and dammed it. I originally programmed for 1550 with a 10 minute hold, but it wasn't flattened out, so I added time and temp and ended up at 1580 over about 15 more minutes. It flattened out somewhat, but it didn't flow on the surface like BE or Spectrum. There was of course some devit which was expected but I really want it to flow out to a smooth surface.
Its not as flowy at the other posh glass U mentioned
Yes flux of some sort will help it flow n prevent that lovely devit
My current method is 2 increace temp slowly at 20 c hour
Formaly Dvit Boy
Dave Pascoe
Hi lynne,
I work with float a lot and I`d say that you need to soak for a bit longer.Float doesn`t seem to flow like BE for example.I`d go up to 1520 but maybe come up from 1200 to 1520 quite slowly,try 100 dph.Then cool quickly from 1520 to 1200 and anneal as usual.
I don`t seem to have devit problems,not yet anyway!!!!!
Hope this helps,dave.
Lynne Chappell
Thanks for the tips. I thought I should heat rapidly to help avoid the scum on the surface which seems to get in the way of the flow. You see, I don't have a solid sheet surface on top, but a pile of frit of various sizes. This seems to cause a lot more trouble than a solid piece. I think I'll have to break down and throw in some borax or maybe some of Brian's flux, if I can remember what he uses (and translate it from the English).
What I'm trying to get is a look like frothy waves. So the devit is OK - it adds to the look, but I want the surface flat. If I can't get it with the frit on top, I'll have to add a thin cap of clear, but I'm afraid the bubbles in the gaps in the frit might get large and ugly.
Lynne
Lynne
Once U got the devit it will get worce n stop the glass flowingLynne Chappell wrote:Thanks for the tips. I thought I should heat rapidly to help avoid the scum on the surface which seems to get in the way of the flow. You see, I don't have a solid sheet surface on top, but a pile of frit of various sizes. This seems to cause a lot more trouble than a solid piece. I think I'll have to break down and throw in some borax or maybe some of Brian's flux, if I can remember what he uses (and translate it from the English).
Lynne
The borax should stop the devit
Fast fire is one method U could use
