Cutting double thickness Spectrum 96
Eleanor Brownridge
I have been fusing simple kitchen still life scenes (fruit, wine bottle etc.) on Spectrum 96 -- a 10" x 12" oval to use in stained glass. Two out of 3 times stress cracks developed originating from seams between the thick and thinner glass. I've tested all the coloured glass (Spectrum) and it doesn't seem to be COE incompatability. So I deduced it was stress because of the different thickness of glass. I used very conservative annealing schedules.
In desperation I bought double thickness Spectrum 96 ... but now I can't cut it with my standard cutting tool.
Any suggestions?
Desparate Eleanor
Any suggestions?
Desparate Eleanor
TurtleCreek Art Glass in Nottawa, Ontario
Terry Craig
Eleanor Brownridge
Fusionistic
That's a good tip. I've been working with the thicker glass as well, and it is a bit of a bear to cut. The running pliers I use have a screw adjustment that determines how tight they can close -- I need to adjust this to a thicker setting to get a better break (and then I need to remember to reset it or I can't figure out why the heck I can't break normal glasscharlie wrote:do a search in the old archives as there's been lots on this in the past.
cutting thick glass can be done with an ordinary cutter, however it's easier with a different cutting wheel. the thicker the glass the wider the wheel angle.
But, the best I can manage still leaves a few places where the break runs wild, and these need to be cleaned up on the grinder.
Doug Bailey
Judy Schnabel
I've been cutting circles from System 96, double thickness clear with a regular Silberschnitt circle cutter without a problem. For straight cuts, I use a regular Silberschnitt glass cutter. I do use a Toyo thick glass breaking tool on the straight cuts to run the score. On the circles, I follow Patty Gray's circle cutting technique (http://www.pattygray.com) which allows me to cut the circles without wasting any glass. The scores run easily in the 1/4" thick glass using her technique.
Eleanor Brownridge
Thanks for all the suggestions. I read them all and searched the archives -- then went out to my studio and used my hammer a little more aggressively on the back side. Behold the score ran and I've even managed to cut a circle.
I guess I was just scared after feeling like a pro cutting regular glass.
Eleanor
Eleanor
Terry Craig
