A current one-off project involves painting on a piece of float which is going to be glazed into a triple pane sealed unit.
I'd prefer to go with a low fire enamel to avoid any deviation from perfectly flat in the piece,but the archives, and Brad in particular, are not very positive about the longevity of the Pebeo product.
Pebeo, Fusemaster, Reusche? Any feedback regarding the use of these enamels is greatly appreciated.
Allan
						Paint experiences
				Allan Gott
				Avery Anderson
Alan
Since your glass will be sealed inside a triple glaze, I think you have several options. You can use transparent enamels that fire in at 1050ºF and not bend the base glass. You can use Peebeo or similar low fire enamels. These enamels are removable with a razor blade, but since they are encapusalated, I think you are OK. The choice really depends on the look you want.
For low fires,I would also look in to Ferro's organic bottle coating colors or ICD's AquaVue colors. both are professional versions of products similar to Peebeo.
For 1050 Enamels, there is Reusche, Fusemaster, or one of the other companies that imports European transparents. Mr & Mrs somebody...
Be careful with any of the low-fire Reusches which cure out at about 1050 degrees.  The potential problem, in a sealed unit as you describe, is the risk of corrosion to the low-fire paints.  When the unit leaks in 10-12 years, the combination of water vapor, dessicant, and solar can create nitric acid resulting in an etching effect.  Does your painting have to be sealed in an insulated unit? Or can you check on another kind of sealed unit that is charged with an inert glass like argon which might by-pass that problem?  Check with the glazing company making the units.  PM us direct if you have more questions.
~Mike
						~Mike
				Allan Gott
