bubble question
bubble question
Just made a one layer plus design plate and got a bubble in the middle...it did burst... Can I refuse it ? Will it flatten if I put a small frit on the outside os the rim allowing air to escape?
Re: bubble question
Yes, refuse it.doctac wrote:Just made a one layer plus design plate and got a bubble in the middle...it did burst... Can I refuse it ? Will it flatten if I put a small frit on the outside os the rim allowing air to escape?
You can repair it in many ways, including what you propose. Brock
Bubbles
Brock is correct; he always is so listen when he speakes.
My response to bubbles, as with some other problems, is that it's best to avoid them rather than trying to fix them. When I flat fuse I found that the thickness of the piece as well as my firing schedule both acted to cause, or defeat bubbles.
I used to do two layer stuff and used to get horrible bubbles; went to three layers and the bubbles went away.
I used to go to 1500 for a full fuse and got terrible bubbles; went to 1450 with an hour soak and the bubbles went away.
I used to fire pretty fast above 1200; slowed WAY down in that range and the bubbles went away.
I used to blame bubbles on warped kiln shelves. Well, I still do, but there seems to be more to it.
Hope some of that helps.
jerry
jerry
Jackie Beckman
