Fixing Sagging Elements
Riverviewglass
My Paragon kiln elements have been sagging and the pins have been falling out - I finally got some replacement pins and now want to replace them - My question is that with heating my element to about 300 degrees I am going to have to wear gloves to insert them - my gloves are so big on my hands I don't know if I will be able to grab onto the pins and shove them in. Any suggestions? I checked at Ed Hoys this past week and all the gloves I found were large on me.
thanks for any help! Kim
Riverviewglass
Judith Andre
Greg Rawls
Mike Byers
When reinserting pins I've found that putting a slight bend in the pin (at about the center of the long part) makes the pin fit tighter. This "spring fit" technique helped keep the pins from falling out in my ten year old Paragon, just like putting a very slight bend in a door hinge pin will help keep a door open in the position you want. But I wonder if you could find a source of the wire that the pins are made from and make U-shaped pins with equal length sides? Maybe pins like this would be better?
you can also get a 10' spool of wire and make your own: http://delphiglass.com/index.cfm?page=i ... o=itemListBrad Walker wrote:Any pottery place will have element pins. Or you can order them from any kiln or element manufacturer.Greg Rawls wrote:Does anyone know where to find these pins? Is there an internet source where I can order them from? Thanks!
Riverviewglass
Marc Demian
form fitting gloves
Last Xmas they were advertising something called "Ovgloves". I decided to try them out. I find them much more agile than my expensive giant padded gloves from C&R Loo. They may not be quite as heat resistant, but perfect for moving hot shelves or handling hot kiln handles. I seldom use my big bulky gloves anymore.
I bought mine at Walgreens but I'm not sure if anyone still carries them or if they were an Christmas wonder. $20 each I believe.
Carol Craiglow
Has anybody tried these Coolhands Kevlar gloves from CDV? They are only rated to 800F, but they look very flexible.
http://www.cdvkiln.com/menuacc.htm
Carol
Carol
Bob L Workshop - Take Two
June 10-11-12
Santa Fe NM
June 10-11-12
Santa Fe NM
I have some of the kevlar gloves as well as the sleeves from CDV. I bought them 2 or 3 years ago. I use them for glory hole work. The gloves do a good job with the heat from a full size glory hole.They fit well and there is no problem with dexterity. I would highly recommend the sleeves be used with the gloves I don't know how they would be for raking and other kiln work..I use the heavy duty gloves for that.
jim
jim
gerry newcomb
I've found a real easy way to push around/ shink or stretch elements is to use a propane torch to heat a section of the element to move it to where you want to. Needle nose pliers are a help for handleing the elements.
I keep a roll of nichrome wire in the studio and make my own pins, element holders wall supports etc. Good luck
