Good morning! Could you tolerate another question from a novice?
My husband recently bought a Craftsman variable speed grinder. Is there any reason why I couldn't use this to grind the edges of my glass pieces? Is there a special wheel that I should purchase?
Thanks very much!
Joanne
Equipment question from a novice
Re: Equipment question from a novice
You need water to cool the glass and lubricate as you grind, diamond or silicon carbide (might have that last one wrong) grinding pads, belts or disks to grind with. If the grinder will work with a water feed (must be made to work with water so don't try it if it isn't) and there are diamond surfaced grinding bits that can attach to the grinder, then I expect it might work...Glassyeyed wrote:Good morning! Could you tolerate another question from a novice?
Thanks very much!
Joanne
My concern would be that it isn't intended to be used with water or on the materials you want to use it for. You really need something intended for stone or glass for best results. Check out lapidary equipment or glass grinding equipment to find grinding tools that will serve your purposes better.
