http://www.etchworld.com - sand etch sandblaster...
it's tiny and it's cheap so it _sounds_ ideal, but does anyone have any experience with this thing? i just need to sandblast really small things, 4x4" max....will this do?
also, as a possible alternative i was looking into etch bath dipping solutiob, but i was hoping to be able to fire my pieces after i etch/sandblast them to get that satiny look...would that work if it was a chemical etch?
thanksssss
peace
- l
etchworld sand etch...
It will work, but you'll outgrow it quickly and you'll want more.
With that said, try to minimize the amount of grit that gets all over the place by blasting in a cardboard box or storage tub. The clear tubs work better than the opaque tubs since they let light through.
Compared to setting up a sandblaster and cabinet, it's a small investment, so you should go for it. I don't know how long the cans of air will last... I can't imagine you'll get too many pieces out of a can, but I would be curious to know what you learn.
