Kiln Supplies
Spend $200 after discount on your total order, get FREE shipping to US locations
Kiln Wash / Shelf Primer
Bullseye brand kiln wash goes on pink and changes to a neutral color after firing.
Mix four to five parts water to one part kiln wash and apply five coats to your kiln shelf or mold.
Bullseye Kiln Wash
3 pounds / $31.95
Add to Cart
Bullseye Kiln Wash
14 ounces / $9.95
Add to Cart
Hotline Primo Primer is a single use kiln wash that works well on intricate casting molds or at higher temperatures.  Mix four parts water to one part primer.  Apply four or five coats.
After firing, clean with a damp paper towel or sponge.  No scrubbing or scraping required.
Warning: it may stick to the glass if used for more than one firing.
Primo Primer
6 ounces / $5.50
Add to Cart
Armstrong Ceramaguard
Ceramaguard is the only ceiling tile that can withstand fusing and slumping temperatures in the kiln.  It makes a great drop ring, dam material, or even an inexpensive kiln shelf.  Learn more in the video below.
If you live outside the continental US and are interested in purchasing Ceramaguard, please contact us to get an estimate of shipping costs before ordering – the calculation in the cart may not be accurate for those locations.
3 pieces, about 11 1/2" square
$35.95
Add to Cart
Please note: the edges of the Ceramaguard may be slightly ragged.
Bullseye ThinFire Shelf Paper
ThinFire shelf paper is used as a separator between glass and the kiln shelf. It’s lightweight and about the thickness of a sheet of paper. It provides a smoother finish on the bottom surface of your glass than kiln wash and requires less preparation time. Use it once — it will turn into powder. The residue can be cleaned with a vacuum (please use a HEPA filter) or with a damp paper towel.
20 sheets / $105.00
Add to Cart
100 sheets / $440.00
Add to Cart
Save 10%
Free shipping to US
Narrow Roll -- 65' x 20.5"
$246.60
Add to Cart
Save 10%
Free shipping to US
650' x 41"
$1044.00
Add to Cart
Save 20%
Free shipping to US
Fiber Paper
Fiber paper is a flexible product that is easy to cut and to shape as desired.
550 Fiber Paper
4 sq ft -- 1/8" thick
$32.95
Add to Cart
550 Fiber Paper
10 sq ft -- 1/8" thick
$75.95
Add to Cart-->
We carry two different types of fiber paper.
Our 550 paper is 1/8″ (3mm) thick and is great for use in kilncarving or to line dams.
Our 970 paper is 1/32″ thick and is best used with punches or where only a very thin layer of paper is desired.
Click here for health and safety information on fiber paper.
970 Fiber Paper
10 sq ft -- 1/32" thick
$24.95
Add to Cart
Wire Mesh
We sell premium stainless steel mesh with 1/2″ squares, useful for wire mesh melts. The mesh is welded together using Type 316 stainless, which is superior in quality to most other stainless steels.
 Contact us for custom sizes.
Stainless Steel Mesh
12" x 11"
$16.00
Add to Cart
Boy not included
17" x 17"
$32.00
Add to Cart
Boy not included
