Warm Tip: What’s the difference?
Can you tell the difference between these two tiles?
Look closely….
Look closely….
The tile on the left has a layer of clear on the bottom while the tile on the right has a layer of clear on top.
Fusing with clear glass on the bottom is great for allowing bubbles to escape easily however it usually leaves the edges of the glass uneven after firing.
Fusing with clear glass on top can show bubbles but the weight of the clear glass allows for more even edges after firing.
Which way is the best way you ask? Now that is up to you to decide! 😃
More Warm Tips
Let’s talk 550 Fiber Paper!
October 12, 2020
This flexible 1/8″ thick paper has many uses.
Removing Stuck Kiln Wash
September 22, 2020
Tips on how to remove stuck kiln wash from your fired pieces
Thermal Shock or Annealing?
September 22, 2020
Anyone know which crack is annealing and which crack is thermal shock?
Kiln Washing the Shelf
September 10, 2020
It is so easy to throw a piece of thinfire on the shelf but there are times when you need to use kiln wash such as high temp firing or when using molds.
